Activity Forums Apple Motion Changing global keyframe speeds
  • Changing global keyframe speeds
    Posted by Bill Mcguire on March 9, 2006 at 11:18 pm
    I have 10 images on a layer that I have keyframed in four corner movements over a 15 second period, and now need to change about half of them to about 10 seconds. I’ve highlighted the ones I need to change, but have experimented to compact them (without clipping them) and am at a loss.
    Does anyone know of a way to do this without saving as a QT and reimporting?. I want to save the behaviors and keyframes at the accelerated speed.
    Bill Mcguire replied 20 years, 6 months ago 3 Members · 4 Replies
  • Mark Spencer
    March 10, 2006 at 6:19 am
    In the timeline, turn on keyframes (little purple button bottom left) and slide them over. Trim the behaviors.
    Mark Spencer
    Freelance Editor/Producer
    Apple-certified instructor, FCP, DVDSP and Motion
    Author, Motion Visual Quickstart Guide from Peachpit Press
    https://www.applemotion.net
  • Bill Mcguire
    March 10, 2006 at 6:03 pm
    Thanks Mark, but I’ve already tried that, but I still must be doing something wrong.
    When the keyframes are showing (diamonds are visible) with the object above them, and I select all the keyframes in a group and slide them, they still keep the same length. They are just moved to a different position. If I select one key, it just moves the one key. I still haven’t been able to condense the in/time out points to shorten the time period of the entire series of keys. All I have been able to do is either move the entire series or clip off the end ones.
  • Greg Niles
    March 10, 2006 at 6:10 pm
    Motion has a cool trick to compressing groups of keyframes in time – if you hold Option while dragging the last keyframe in the timeline (no need to select them all), it will compress or expand all keyframes in time as you drag left or right.
    — Greg
  • Bill Mcguire
    March 11, 2006 at 5:11 am
    Thanks Greg… Worked great!
