Activity › Forums › Apple Motion › Changing from DV to Hd Workflow
  • Changing from DV to Hd Workflow
    Posted by Jimr on February 3, 2006 at 3:55 pm
    Made Titles in Pal DV for offline, Now must supply these title animations in HD or Uncompressed DigiBeta onlines.
    what is the easiest workflow to convert in motion and keep same size relationship
    if I copy and paste from SD To HD Then I have to Resize by Eye must be an easier way.
    Also do I export as Quicktime Lossless+ alpha for Best Quality.
    Thanx
    JimR
    Jimr replied 20 years, 8 months ago 2 Members · 2 Replies
  • Noah Kadner
    February 3, 2006 at 4:10 pm
    That’s about it- totally different resolution, framing and frame rate so there’s no automatic way if you want it to look rate.
    Noah
  • Jimr
    February 3, 2006 at 8:17 pm
    Thanx for feed back.
