Activity Forums Adobe After Effects Changing Frames Per Second Turns My Project Into A Demon!!!
  • Changing Frames Per Second Turns My Project Into A Demon!!!
    Posted by Jay Toss on August 18, 2011 at 7:00 pm
    So I’m stuck on changing the Frames per second!?
    I started the project at 25 FPS but i didn’t realize my footage is 29 FPS until after i did all my animation etc.
    Project
    1920/1080 – Footage is .mov at 29 FPS and there is animation
    When i change the FPS within the composition
    All the audio changes pitch??! ( the demon sound )
    And i don’t know if its just the demon sound making the footage seem slower???
    I tried changing the FPS in the same project comp. that didnt work.
    then i took the whole project comp and put it into a new comp with 29fps
    that didnt work!!! ERR$*@%&%*
    What am i doing wrong???
    Thanks in advance
    Jay Toss replied 15 years ago 39,547 Members · 2 Replies
  • Jay Toss
    August 19, 2011 at 9:44 pm
    just to clarify.. the audio of the footage is fine (Im also not using the audio from the footage) its just i have one song playing threw out that the pitch is changing into the demon.
    I tried bringing that audio back in with a different file name but after a ram preview the audio turned demon!!
    PLLLZZZZ ANY HELP!!!
  • Jay Toss
    August 19, 2011 at 11:38 pm
    FIGURED IT OUT!! Even tho i changed the FPS in the comp settings… The Ram preview settings still said 25 fps even tho it should say 29.97!!
    thanks anyways!
