Activity Forums Adobe After Effects Changing frame rates in a PAL composition
  • Changing frame rates in a PAL composition
    Posted by Ross Marshall on September 24, 2009 at 2:28 pm
    Hi wandered if anyone can help. Putting together a effect shot in After effects in PAL at 25 frames a second. Problem is using some stock footage that is 30 frames a second. I know how to change it in after effects but it still looks jerky. Understand Andrew Kramer has a frame converter but how do I get hold of it and how much is it. Also can you do it without buying a plugin?
    Thanks in advance.
    Ross
    England
    Ross Marshall replied 17 years ago 1 Member · 0 Replies
  • 0 Replies
