Activity › Forums › Apple Final Cut Pro › CHanging Frame Rate
  • CHanging Frame Rate
    Posted by David Schmidt on September 12, 2011 at 11:33 pm
    I am having to edit some footage that was given to me. The footage is P2 and the frame rate is 59.94. How do I change it to 29.97? Do I just retime it by 50%? Seems there should be a way to assign a specific frame rate.
    Jeremy Garchow replied 15 years ago 2 Members · 1 Reply
  • Jeremy Garchow
    September 13, 2011 at 1:05 am
    You can only adjust percentages. If you put that clip in the timeline and use “conform speed” it will adjust to the proper time.
