Changing fps from 25fps to 30fps and locking keyframes and edit points to the nearest integer frame number
Hello,
is there a way to lock keyframes and edit points to integer frame numbers?
I am converting a heavily keyframed comp from 25fps to 30 fps and need frame accurate edit points and keyframes.I was hoping an expression or a script may save me a lot of time and effort.
Let me know if anyone has any ideas.Many thanks – Chris
Christopher Johnstone
