Activity Forums Adobe Premiere Pro changing font type and size in mogrt file templates
  • changing font type and size in mogrt file templates
    Posted by Scott Patterson on April 10, 2019 at 9:11 pm
    hey there,
    this issue driving me a bit nuts. Seems can’t change the font easily using purchased mogrt templates within PP . I’m on 2018 version, and just cant go to 2019 at the moment ( i understand that is a huge update). Whats odd is that some templates within PP, I see there is some ability to change the font type. But anything created with AE it seems , there’s a long process to do the font change…and even then can’t seem to change the font size.. seems so odd, and makes the templates pretty useless.
    Does anyone have any clarity, insight, workarounds, or know where I can buy some templates where the font is adjustable.
    many thanks
    scott
    Patrick Finnegan replied 6 years, 10 months ago 3 Members · 2 Replies
  • John Pale
    April 11, 2019 at 1:31 am
    2019 enables creating Mogrts with the ability to change fonts.
    No workaround for earlier versions.
  • Patrick Finnegan
    October 29, 2019 at 11:31 pm
    If you need to modify an existing mogrt to allow font changes:
    Add.zip to the end of the mogrt filename
    MyTitle.mogrt -> MyTitle.mogrt.zip
    Open the zip and extract the .aegraphics file
    Add .Zip to the .aegraphics file
    MyTitle.aegraphics -> MyTitle.aegraphics.zip
    Open the zip and extract the .aep file
    Open the .aep file on AE
    Open the Essential Graphics panel
    Next to the text field you want to modify, click on Edit Properties
    Check the box that says “Enable Custom Font Selection.”
    If you want, also check the other boxes.
    Click the Export Motion Graphics Template button a the bottom of the Essential Graphics panel.
    Save the new mogrt and then install it in Premiere.
    You should now be able to change the typeface and font in Premiere.
