Activity Forums Avid Media Composer Changing File Names after Importing Audio
  • Changing File Names after Importing Audio
    Posted by Jenna Bliss on July 24, 2009 at 9:38 pm
    I am importing over 100 .aiff files and converting them to MXF on the import. All the filenames on all the cds are the same – if I were to go into the bins and change the file names to something unique after the import would that cause problems down the road? Maybe in the sound mix?
    Jenna D Bliss
    Jenna Bliss replied 17 years, 1 month ago 3 Members · 3 Replies
  • John Pale
    July 25, 2009 at 2:45 am
    No. The clip names in the bins are not important. Actually, Avid generates a lengthy number for each piece of media when captured or imported…it doesnt use the filename at all…(or the file itself for imported media—it creates a new file).
    The only problem might be if you have to batch re-import it later and you dont know what track number it is. Make sure you include that in your naming scheme.
  • Terence Curren
    July 25, 2009 at 6:03 pm
    You could automate this a bit by ripping your CDs into iTunes first as it will check the internet and assign all the names. Then just import those libraries.
    Terence Curren
    http://www.alphadogs.tv
    http://www.digitalservicestation.com
    Burbank,Ca
  • Jenna Bliss
    July 27, 2009 at 1:30 am
    Jenna D Bliss
