Activity Forums Apple Final Cut Pro Legacy Changing field order on 1000 dv files
  • Changing field order on 1000 dv files
    Posted by Anders Haavie on August 5, 2009 at 7:45 am
    Is there any way to easily change field order on lots of qt dv-pal files ? I have been told that our Avid guys need dvpal in upper field.
    Anders
    Xraid-Xserve-Xsan-Xeverything
    Shayne Weyker replied 17 years, 1 month ago 5 Members · 5 Replies
  • Bouke Vahl
    August 5, 2009 at 8:43 am
    No, he doesn’t
    Avid can switch it on import if needed…
    But you’ll have other problems, like perhaps loosing metadata.
    What are you trying to do?
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pro’s
  • Massimo Croce
    August 5, 2009 at 8:51 am
    [Anders Haavie] “I have been told that our Avid guys need dvpal in upper field”
    Why? Dvpal is always lower first…
    and avid can invert the field in import preference..
    Anyway, you can do this by importing your dv file in fcp loading every clip in the canvas apply a shift filter and batch export all clip from the browser with the effect applied.
    Massimino
  • Michael Gissing
    August 5, 2009 at 10:09 am
    The only lower field order PAL signal is DV regrettably. Your AVID friends are wrong.
  • Anders Haavie
    August 5, 2009 at 10:27 am
    He told me that changing field order on the import didn’t work in Avid. I don’t know Avid good, so I am not sure what is wrong. I guess I will just give him qt dvpal lower (standard) and let him figure out what to do.
    Anders
  • Shayne Weyker
    August 5, 2009 at 5:04 pm
