Activity › Forums › Apple Final Cut Pro Legacy › changing field dominance for file [tiff] import
Posted by Rick Broat on April 13, 2008 at 5:12 pmI would like to change file import from none to lower field when bringing in tiffs. Is there and option for that?
Scott Thomas replied 18 years, 4 months ago 4 Members · 8 Replies -
David Roth weiss
April 13, 2008 at 5:14 pmTiffs do not fields, so changing the field dominance setting will have no effect.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
Rick Broat
April 13, 2008 at 5:55 pmIn the browser they are coming up as none in field dominance column. I am seeing what looks like field mismatch on my bcast monitor when I play the seq down. I did find that if i control click on none it allows me to change from none to lower. In avid world field dominance matters w. tiffs….
David Roth weiss
April 13, 2008 at 6:02 pmHave you checked “full” in the render dropdown, and have you rendered?
David Roth Weiss
Director/Editor
Rick Broat
April 13, 2008 at 7:37 pmI have, no difference- I think it is my monitor- will check tonight, have a 9p session. thanks for the input.
Bret Williams
April 14, 2008 at 2:02 amAre you sure your tiff isn’t a freeze frame of video where there was motion? If so, it’s not going to matter what the field dominance is, you’re just going to get back and forth vibration no matter what. Doesn’t matter if you play field 1 first or second when you’re playing field 1,2,1,2,1,2,1,2 over and over again. If there’s movement then there’s just normal movement between the fields. The answer is flicker filter or deinterlace.
Scott Thomas
April 14, 2008 at 6:27 amSelect the footage in the bin and press
I to get info on the TIFF sequence. In the column where it indicates field dominance, there is a little, hidden pop-up menu there. You should be able to force it to upper or lower, similar to the footage settings in After Effects. TIFF sequences can have fields just like anything else.
David Roth weiss
April 14, 2008 at 4:08 pm[Scott Thomas] “TIFF sequences can have fields just like anything else.”
You may well be correct Scott, but the original post says nothing about “sequential” tiff files.
David Roth Weiss
Director/Editor
Scott Thomas
April 14, 2008 at 5:45 pmHe was more specific in his second post.
“I am seeing what looks like field mismatch on my bcast monitor when I play the seq down.”
