Activity Forums Adobe Premiere Pro Changing fade duration on multiple tracks of audio at once?
  • Changing fade duration on multiple tracks of audio at once?
    Posted by Scott Clements on May 5, 2015 at 1:49 pm
    Been wanting to know how to do this for ages. If you put 6 dissolves on 6 tracks of audio and change your mind about the duration, how do you quickly change them all at once? Currently, I am having to double click on each one and it’s really slowing me down. Is there no easy way to change them all at once?
    Film Editor, London UK
    http://www.scottclementseditor.com
    Scott Clements replied 11 years, 4 months ago 2 Members · 2 Replies
  • Craig Howard
    May 5, 2015 at 11:56 pm
    You will get a lot faster when you get it right first time.
    Just messin’ with ya!
    You did apply them one by one so fixing them the same way is the only way really.
    For me..I do Cross Fades in the Audio Track Mixer (Automated Write /Read)
    FWIW – If I add fade-outs to tidy up ends of audio clips…I check they work as I do them.
    Craig Howard
    Shooter Film Company
    Auckland
    New Zealand
    Adobe CS6 Premiere Pro Production Premium Suite
    Windows 7-64 bit:Assus P6T Deluxe Mob, 24 GB BM SDI Decklink, . HD Workflows
  • Scott Clements
    May 6, 2015 at 12:03 am
    Sorry, Craig, I meant audio dissolves. I actually apply them all at once, to all six tracks – I select the end of all six tracks and use a keyboard shortcut. It’s just when I want to change them that I have to select each one individually to adjust its duration.
