Changing easy setups for existing sequence
Hello,
I created sequence with the wrong Easy setups – PAL and DV , and wrong sequence settings:
frame Size: 720×576 CCIR 601/DV PAL (5×4)
Pixel Ratio: PAL – CCIR 601 (720×576)
Field: Lower
Editing: 25
Compressor: DV-PALWhen i transfered files it didn’t ask me to change the settings so i sterted editing without changing anything.
Afetr a while i figured that i did it wrong and i change it to the proper settings;
Easy setups:
Format: HD Rate:25
Use: DVCPROHD – 1080i50And sequence settings:
Frame size: 1920×1080 HDTV 1080i(16×9)
Pixel: Square
Field: Upper
Editing: 25
Compressor: XDCAMEX 1080i50 (35mb/s VBR)Now the video looks very small in the frame.
Is there any chance to change it?
I hope it is, cause otherwise i will have to start editing from the beginning :/
Please help if you canMartha
