Activity Forums Adobe After Effects Changing Easy Ease Keyframes
  • Changing Easy Ease Keyframes
    Posted by Jimmyjimmy05 on May 8, 2006 at 9:05 pm
    Is there anyway to turn easy ease keyframes back into normal ones? I have been working with a project and the text moves slightly between two keyframes because they’re easy ease. Am I better off just redoing the keyframes normally?
    Jimmy Jimmy
    Jimmyjimmy05 replied 20 years, 4 months ago 4 Members · 4 Replies
  • Fabiano Peres
    May 8, 2006 at 9:16 pm
    Hi friend
    Hold down Ctrl and click it. That’s it.
    Big hugs from Brazil
  • Michael Duff
    May 8, 2006 at 11:00 pm
    or right-click on the keyframe and go “interpolation” – there you have all the settings for both spacial and temporal interpolation.
  • Mmhmichael
    May 9, 2006 at 6:18 am
    make sure that if you have two keyframes in between which you DON’T want to have any movement/animation, you set the first (incoming) keyframe interpolation to ‘hold keyframe’. you can do this by right-clicking and selecting the keyframe interpolation.
    i didn’t learn this until about a year into after effects and it always helps me a lot.
  • Jimmyjimmy05
    May 10, 2006 at 9:37 pm
    Thanks a lot man, both of your responses helped me out a lot!!!
    Jimmy Jimmy
