Activity Forums VEGAS Pro Changing dissolve length after running Excalibur 4.5 Multicam
  • Changing dissolve length after running Excalibur 4.5 Multicam
    Posted by John Frey – digital west video productions on August 11, 2005 at 5:20 am
    We just purchased and installed Excalibur 4.5 in Vegas 6. After cutting together a 3 cam shoot in Multicam using the default 16 frame dissolve at every switch, we would like to change these dissolves(91 in all)to 30 frames each in duration. What is the quickest and easy way to do this if any? Any help would be greatly appreciated.
    Edward Troxel replied 21 years, 1 month ago 2 Members · 1 Reply
  • Edward Troxel
    August 11, 2005 at 1:26 pm
    The QUICKEST way would be to click on Undo and change the default to 30 frames. I recommend always saving a version just prior to running Multi-cam. That way you can always return to that point should you decide to change something later.
    At this point (assuming Undo is not an option), try this:
    a. Delete the Master track
    b. Run Multi-Cam again using the revised default dissolve setting
    Edward Troxel
    JETDV Scripts
