Activity Forums Maxon Cinema 4D changing direction of a spline (sweep nurbs)
  • changing direction of a spline (sweep nurbs)
    Posted by Neil Stubbings on April 25, 2006 at 8:52 am
    i have a sweep nurbs with a growth animation for a logo animation.
    The groth animates in the wrong direction… Can I change the direction of a spline/sweep nurbs?
    Tim Rice replied 11 years, 8 months ago 4 Members · 4 Replies
  • Scott Frizzle
    April 25, 2006 at 3:13 pm
    Select the spline, then go to structure> edit spline> reverse sequence. Done!
  • Tim Rice
    June 13, 2014 at 7:59 pm
    For R15 users: select the spline, switch to point editing mode, right click on the viewer and choose “Reverse Sequence”, then left click on the scene to update the viewer.
  • Naeem Rabbani
    January 3, 2015 at 11:45 am
    Hi
    Just started using c4d. Don’t know how to switch to point editing mode and hence my right click isn’t working. How do I fix that…thanks
  • Tim Rice
    January 3, 2015 at 8:08 pm
    Left of your view port there are about 10 icons, it’s the one that’s a cube with two dots on it. You can also go to Tools>Modes>Points. At any point you can right click on something to open the help file. This help file is the best help file of any program i’ve ever used. Seriously, live by it!
