Activity Forums Avid Media Composer changing default title tool font and size
  • changing default title tool font and size
    Posted by Mark Anderson on April 1, 2005 at 4:06 pm
    i can’t find this anywhere, is there a way to change the default font and size that title tool chooses when you open the program? thanks
    mark anderson
    Carl Amoscato replied 21 years, 3 months ago 3 Members · 3 Replies
  • Carl Amoscato
    April 1, 2005 at 4:24 pm
    I don’t know about changing the default, but you can save a style and assign it to a function key. For example we use Arial 26 bold with a 3pt shadow every day, so I saved that style and assigned it to F2, so when I open the title tool and press F2 I’m ready to go. May not be exactly what you’re looking for, but might be close.
    good luck,
    Carl
  • Travis Boyle
    April 4, 2005 at 3:23 am
    That’s a great idea, that I didn’t know was possible. How do you do it…assign Title tool presets to function keys, that is.
    Travis
  • Carl Amoscato
    April 4, 2005 at 8:34 pm
    After you create and save a style in the Title Tool, it will show up under the Settings tab of the Project window. Double click the style name in the Project window, and enter the function key you want to assign it to in the Function Key box. That’s it.
    good luck,
    Carl
