Activity Forums Adobe After Effects Changing Default Output Module Settings
  • Changing Default Output Module Settings
    Posted by Stephen Curry on September 24, 2011 at 2:13 am
    Hi guys, Im hoping someone can help me out. When I Render a project I almost always render it out as Quicktime .mov.
    However when you drag you comp to the render que it defaults as Lossless .avi so I have to always go and change the setting.
    Is there a way to change this default from .avi to (oh lets say) .mov.
    would save me a lot of clicking.
    Cali Pvp replied 11 years, 7 months ago 5 Members · 7 Replies
  • 7 Replies
  • Todd Kopriva
    September 24, 2011 at 3:37 am
    The instructions are in After Effects Help. Click this.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Stephen Curry
    September 29, 2011 at 4:30 pm
    Hi
    Yea Ive been to that part of the Adobe help page but it doesnt do what I want it to do.
    I copied about 39 comps into the render que.
    As it stands now all of them are Lossless .avi and I want them .mov+Alpha
    I even created a template and selected all the comps but it still just changes the one comp.
    So Im either not understanding how to do this correctly and if someone could give me a step by step solution OR for some reason its not working for me…I dont understand why though
    Steph
  • Todd Kopriva
    September 29, 2011 at 4:35 pm
    This video tutorial shows how to change multiple output modules simultaneously:
    https://www.video2brain.com/en/videos-3995.htm
  • Stephen Curry
    September 29, 2011 at 4:58 pm
    OK thanks for the video link
    but that must be a CS5.5 function cause it doesn’t work that way in CS5.0
    Ive found that If I throw one comp into the render que and hold [cntrl] and select my .mov+alpha template for the output module it will change that one comp…and then additionally change all future comps dragged to the render que….but i have to do the above first…
    Otherwise
    if I have a new project with a new comp and it defaults to the lossless .avi and I drag all 30 comps at once to the render que they are consequently all lossless .avi as well and if I select them all and then click on output module (on the first of the selected comps) and change it to .mov+alpha it will ONLY change the comp I messed with the output module settings and not all the selected ones as well….
    so at least i now know I can do it the first way describe above until I can get CS5.5
    thanks
  • Arjun Khanna
    March 23, 2013 at 3:52 am
    hey, when you are in render queue, click on Edit=> Template=> and change whatever the format you need… it defaults…
  • Alex Wawroski
    August 1, 2014 at 10:28 pm
    I don’t know if you’re still using CS5 after all this time like I am. But I just changed the default “lossless” template to the Quicktime settings I want. So it still always goes to “lossless,” but now that’s the settings I’m using.
  • Cali Pvp
    January 24, 2015 at 6:16 pm
    This really helped me. Thanks
