Activity Forums Adobe After Effects Changing Default Layer Style Settings?
  • Changing Default Layer Style Settings?
    Posted by Kevin Han on January 22, 2020 at 6:20 am
    I was wondering if it’s possible to change the default layer style settings for say, the Drop Shadow. For example, let’s say I want to change the Opacity from the original of 75% to 100% every time. Is this possible to do?
    Kevin Han replied 6 years, 7 months ago 3 Members · 4 Replies
  • John Williams
    January 22, 2020 at 9:54 am
    Hi there. If you’ve been using After Effects for a while you may be aware that ‘everything is possible’! Just not always in the way you might think:
    To customise the Layer Styles is the same as customising the Effects. Once you’ve applied it and adjusted the setting to how you wish them to be (ie 100% opacity, different colour…) then select the Layer Style on the layer and go to Menu: Animation / Save Animation Preset.
    This will save the changes into the Presets folder and then you can always find it in the Effects and Presets menu.
    Hope that helps;)
    John Williams
    Soho Editors
  • Kevin Han
    January 22, 2020 at 1:21 pm
    Oh wow, that’s very interesting to hear. I’ve been using AE for about a year now but did not know that lol. Would it be possible then to bind that preset into a keyboard shortcut? ???? that would be awesome as it’s one step closer to automation~
    Thanks for your help!
  • John Williams
    January 23, 2020 at 10:22 am
    Then i’d recommend the FX Console to you for faster access to effects.
    https://www.videocopilot.net/blog/2018/05/fx-console-updated-to-v1-0-3/
    All the best;)
    John Williams
    Soho Editors
  • Kevin Han
    January 23, 2020 at 5:54 pm
    Thanks so much!
