Activity Forums VEGAS Pro Changing Crossfade/Transition Length in Multi-Camera Editing
  • Changing Crossfade/Transition Length in Multi-Camera Editing
    Posted by Steve Hardeman on October 10, 2009 at 5:06 pm
    Vista, Vegas Pro 8.0.
    I just did my first multi-camera edit project. Very cool. Only issue I had was that the transitions are all 1 sec. How do I change the setting to a 2 or 3 or whatever length transition I want it to insert when changing from one camera to the next?
    Thank you for your help.
    Todd Kushnir replied 16 years, 11 months ago 2 Members · 1 Reply
  • Todd Kushnir
    October 10, 2009 at 5:26 pm
    From the manual:
    Holding the Ctrl key while choosing a take will create a crossfade instead of a cut, with the alignment and duration determined by the Cut-to-overlap conversion settings from the Editing tab of the Preferences dialog.
    Hope that helps.
    Todd
