Activity Forums Avid Media Composer Changing contrast levels for blacks, mids and whites separately
  • Changing contrast levels for blacks, mids and whites separately
    Posted by Stephensf on September 13, 2007 at 9:26 pm
    I am coming from final cut where you can adjust the contrast levels for highlights, mids and shadows individually. I am sure you are able to do this with Avid but I can’t seem to work it out.
    Any help appreciated.
    Stephen
    Stephensf replied 18 years, 11 months ago 2 Members · 4 Replies
  • Steve Pomerantz
    September 13, 2007 at 9:37 pm
    Which version of Avid are you using?
    Steve Pomerantz
    Digital Ranch Productions
    Sherman Oaks, CA
  • Stephensf
    September 13, 2007 at 9:40 pm
    Media composer
  • Steve Pomerantz
    September 13, 2007 at 10:13 pm
    On Media Composer, I use the Curves tool in the color corrector. Select Master levels and create control points by clicking on the axis line to separate black, mid and high ranges. Then create more points on the in between and drag them around to move levels up or down. Just be sure you don’t let the black level creep up above the mid range levels, etc.
  • Stephensf
    September 13, 2007 at 10:49 pm
    Thanks. Ill give it a try tomorrow.
