Activity Forums Adobe After Effects changing comp settings mid project
  • changing comp settings mid project
    Posted by William Baverstock on April 12, 2005 at 2:51 pm
    Hi All,
    It has been decided that the project I’m working on will be output for direct transfer to DVD via pro-coder.
    The current comp setting, however, is 640×480 square pix for an older media100. When I change over to DV 720×480 .9 pix aspect
    I find that a lot of my placement of text etc. has not stretched with the rest of the comp. (eg, I had text placed just out of frame for a crawl and now it is visible inside the comp area)
    Any nifty trick here, or am I resigned to a lot of tweaking?
    Thanks for any help.
    BB
    William Baverstock replied 21 years, 4 months ago 2 Members · 2 Replies
  • Matthew Daday
    April 12, 2005 at 3:25 pm
    Seeing as you are working in square pixels anyways, you are going to need to squish your graphics in one way or another before going to a non-square NLE. So I would finish your comp at 640X480 square, and the drop that comp into a 720X480 non-square comp and it should fit perfectly but look a little squished. It will look fine in the editing system however. When I work in square pixels, I work at 720X540 and squish it down to a non square 720X486.
    Good luck
    Matt
  • William Baverstock
    April 12, 2005 at 3:57 pm
    Thanks Matt
