Activity Forums Adobe After Effects Changing color of keyframe
  • Changing color of keyframe
    Posted by John Winthrop on July 3, 2017 at 2:24 pm
    Working with so many different keyframes for multiple different properties and effects on the same layer gets very confusing. It is not immediately appearent which effect applies to which keyframe, or which keyframe indicates what value.
    Is there a way to color code keyframes/values or give them any visual quality that would distinguish them from the others? I know the shapes change based on fade type and that it is possible to have them “numbered” but that doesn’t exactly solve my problem.
    Thank you for any help.
    Richard Garabedain replied 9 years, 1 month ago 2 Members · 1 Reply
  • Richard Garabedain
    July 3, 2017 at 3:58 pm
    I wish…and most of us already filed this complaint when keyframes turned from yellow to blue…Good luck
