Activity Forums VEGAS Pro Changing color of hashed lines bounding box in VEGAS Event Pan/Crop
  • Changing color of hashed lines bounding box in VEGAS Event Pan/Crop
    Posted by Neil Pollick on April 26, 2024 at 12:35 pm
    It’s white by default and on some projects/shots I can not see it at all.
    It would be much easier in red for me most of the time.
    So I how can I change the color?
    (searching th forum yielded no results but then again I don’t know what the correct name is for what I call the “bounding box” after Photoshop’s free transform tool)
    Thanks in advance.
    Neil Pollick replied 2 years, 4 months ago 2 Members · 2 Replies
  • Kelly Griffin
    April 26, 2024 at 5:38 pm
    Hey Neil, I’m not sure if inherently there’s a way to change that, but if I had to think of a workaround, could you temporarily lower the transparency of the clip you’re trying to address (click and drag from the top of the video event and pull down the line) and create some contrast so you can see it better? Or, alternatively, temporarily add a “Levels” FX and darken the clip until you get it the way you want it, then delete the FX (?)
  • Neil Pollick
    May 6, 2024 at 5:20 am
    Thanks, I will try that
