Changing borders of a layer without scaling it
I have an Audio Spectrum effect on a circular path, but the layer has it’s bounding box tight in on the circle and you can’t see the spectrum outside it.
What I want to do is to make the edge of the layer the same size as the comp without scaling the contents of the layer, or just make it bigger. Is there a way I could do this simply?
Thanks in advance
