Activity Forums VEGAS Pro changing audio volume in an event
  • changing audio volume in an event
    Posted by Jim on August 12, 2005 at 2:31 am
    Hello,
    Love the forum. I am using Vegas 5 to edit a couple of weddings I shot. However I have come across a problem that I cannot find a solution to. How do you change the audio volume within an event? I have searched the posts here and the web as well. None of the tutorial sites have any info on this that I can find. I am sure it is something simple.
    Jim
    Jim replied 21 years, 1 month ago 3 Members · 3 Replies
  • Edward Troxel
    August 12, 2005 at 3:03 am
    Insert a Volume Envelope and add new points as needed to adjust the volume.
    Edward Troxel
    JETDV Scripts
  • Peter Wright
    August 12, 2005 at 3:04 am
    If you select the audio track and hit V you will see a volume envelope running along the track. Double clicking anywhere on this will insert pivot points which allow you to ramp volume up or down by dragging.
    Peter Wright
    Perth, Western Oz
    http://www.allroundvision.com.au
  • Jim
    August 12, 2005 at 11:00 pm
    Thanks,you guys are awesome.
