Activity › Forums › Adobe Premiere Pro › Changing audio transition settings
  • Changing audio transition settings
    Posted by Eric Merklein on September 24, 2015 at 7:39 pm
    Because the three audio transitions have different properties, I switch between them depending on use.
    Is there a faster way to switch from one setting to another without getting into the effects window and doing it there 30 times a day?
    Thanks much
    Many thanks.
    Eric Merklein replied 11 years ago 1 Member · 0 Replies
  • 0 Replies
