Activity Forums Apple Final Cut Pro Legacy Changing audio sample rates for capture
  • Changing audio sample rates for capture
    Posted by Lawrence Mcdonough on January 27, 2006 at 8:44 pm
    I am editing a project on FCP 5 where the first few tapes audio were recorded at 48khz, 16 bit. One tape that needs to be in the middle of the sequence was recorded at 32khz 12 bit. I have tried to change the sample rates in “sequence presets” but it is not allowed. Created a second sequence in the bin attempting to capture this tape at 32khz. When I went to preferences, “sequence presets” it still would not allow a change. I am stumped. If I do need a second sequence to capture this tape at 32khz, how do I then get that portion onto the Time Line of the first sequence in the proper place?
    Larry
    David Battistella replied 20 years, 8 months ago 2 Members · 1 Reply
  • David Battistella
    January 27, 2006 at 8:49 pm
    Larry,
    Capture it at 32 and then use QT or compressor to convert it all to 48K. Then use those as the media files that you edit with.
    You can accompliush this by creating a 32K project, capturing it all in there and then using compresso to do the batching back to 48K
    David
    I can’t believe it’s not butter!
