Activity › Forums › Apple Final Cut Pro Legacy › changing audio rate on the timeline.
  • changing audio rate on the timeline.
    Posted by Aine Ni fhaolain on September 12, 2007 at 10:45 am
    Hi
    After editing my film and exporting i noticed clicks in the sound and discovered that some of my audio clips on the timeline are 41 khz instead of 48 khz. I know i can drag these clips back into the browser and then export using quicktime conversion to 48 khz and then drag them back onto the time line but i really dont want to do this because i have spent alot of time mixing the audio together.
    Is there a quicker way in which to perhaps select a clip on the timeline and change the audio rate from there?? I have searched the manual but i cant find any solutions.
    thanks
    Aine Ni fhaolain replied 19 years ago 2 Members · 2 Replies
  • Chris Poisson
    September 12, 2007 at 11:41 am
    You don’t have to move them. Just open the original clips on you media drive in QuickTime, export them at 48k and add a 1 or something to the name. Put them in the same folder as the original. When you are done, toss all the original clips and remove the 1 from the names. FCP will link to your new 48k media.
    Have a wonderful day.
  • Aine Ni fhaolain
    September 12, 2007 at 11:43 am
    cool thanks
