Activity Forums Apple Final Cut Pro Legacy changing aspect ratio
  • changing aspect ratio
    Posted by Brice Kelly on April 11, 2011 at 12:05 am
    Hi there Guys and Gals!
    I am working with DVX 100a 24P footage (not advanced) recorded with a letterbox matte on it and canon xha1 24F HD footage recorded without a letterbox matte on it. I’m using FC version 6.0.6. The canon footage has a 16:9 aspect ratio and the DVX 100 has 4:3 aspect ratio.
    Could someone please advise me on how to match the 2 footages so they both have a letterbox look?
    Zane Barker replied 15 years, 4 months ago 3 Members · 2 Replies
  • Rob Grauert
    April 11, 2011 at 12:17 am
    Work in a 4:3 timeline. When you drop the 16:9 footage from your Canon into that timeline, it should shrink look like letterbox. If it doesn’t shrink automatically, you may have to change the scale to 75% and/or change the Distortion parameter in the Motion Tab to -33.33 or 33.33 (can’t remember which one off the top of my head).
    Rob Grauert, Jr.
    http://www.robgrauert.com
    command-r.tumblr.com
  • Zane Barker
    April 11, 2011 at 4:23 am
    I would recommend going for a wide screen look over a letterbox look.
    Wide screen TVs are far more common these days then 4:3 TVs are. With that in mind if you play a video that is permanently letterbox on a wide screen TV you end up with a small image that has black on all 4 sides. And to me that just looks bad.
    **Hindsight is always 1080p**
