Activity › Forums › Apple Motion › changing anchor points
  • changing anchor points
    Posted by Terry Maloney on August 1, 2017 at 3:56 am
    Hi
    I want to rotate a jpg. I want to rotate with the anchor point at the bottom and then rotate the jpg with the anchor at the top. So I set up these keyframes which change the anchor point of the jpg.
    However, the position of the jpg moved up and down. I want the jpg to stay still; but I want the anchor point to change position.
    Can you tell me how to do this? Thank you.
    Cheers,
    Terry ????
    Terry Maloney replied 9 years, 1 month ago 2 Members · 2 Replies
  • Mark Spencer
    August 1, 2017 at 4:16 am
    Use the Anchor Point tool, rather than the Inspector – it changes both Position and Anchor so that the layer stays still relative to the Canvas.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Terry Maloney
    August 2, 2017 at 7:55 pm
    Thank you..
