Activity Forums Adobe After Effects Changing After Effects 7 default language
  • Changing After Effects 7 default language
    Posted by Glen Perez on January 23, 2007 at 7:53 pm
    Hi, ive installed Tha Adobe Production Studio 2, and everything gets installed in english except after effects 7 wich gets installed in spanish… i guess is because sometimes i use the spanish keyboard for some jobs… how do i fix this___
    Glen Perez replied 19 years, 8 months ago 4 Members · 4 Replies
  • Guillaume Charron
    January 23, 2007 at 11:37 pm
    I have the same problem. For me it is in French. And i want AE7 in English. What do we have to do? Reinstall?
    May the force be with you
  • Bill Clotz
    January 24, 2007 at 1:12 am
    Just edit the shortcut to append -L EN onto the end.
    Shortcuts for various languages should already be available in the Adobe\Adobe After Effects 7.0\Languages\ folder, so you could just copy the one you want over to your start menu.
    Also, I think you could just set your system locale to the US and reinstall, and then change it back.
  • Mylenium
    January 24, 2007 at 7:12 am
    Like Zarxrax said, check for the language shortcuts. You may still have to re-install, though, as this does not work with Bridge and Encore.
    Mylenium
    [Pour Myl
  • Glen Perez
    January 24, 2007 at 12:12 pm
    the shortcut works without reinstalling, thanks a lot
