Activity Forums Adobe Photoshop Changing Adjustment layer properties within Layer Comps
  • Changing Adjustment layer properties within Layer Comps
    Posted by Brian Murphy on May 31, 2025 at 5:37 pm
    I can’t find anything on this one – and wondering if it’s either a bug or I don’t have some settings turned on/off.
    I’m simply trying to change my level and Hue/Sat values from one layer comp to another (same document).
    For example, if I have a layer with a box and a hue/sat adjustment layer above it which turns the box red – that’s a layer comp called “Red”. I create another layer comp with that same adjustment layer tweaked to make the box green. If I go back to view the “red” layer comp, the box is green. The tweak to the adjustment layer does not work. I’ve tried re-creating the layers from scratch, or updating the layer comps manually after tweaking…no dice, it’s always showing me the last tweak in any adjustment layer. What am I missing??? Thank you!
    Brian Murphy replied 1 year, 2 months ago 1 Member · 0 Replies
  • 0 Replies
