Activity › Forums › Adobe After Effects › Changing a Value by the same factor on Multiple Keyframes
  • Changing a Value by the same factor on Multiple Keyframes
    Posted by Gabe Aguayo on March 27, 2017 at 3:11 pm
    I made an animation that has multiple keyframes based on position, but I want to move the animation to the left. However, just trying to move the object creates a new keyframe for that position. Is there a way to change every keyframe value by the same amount in the same direction without having to re-do the entire animation?
    Gabe Aguayo replied 9 years, 6 months ago 1 Member · 1 Reply
  • Gabe Aguayo
    March 27, 2017 at 8:49 pm
    Worked perfectly, thank you!
