Activity › Forums › Adobe Photoshop › changing a transparency into a brush
Posted by Kelley Neff on October 22, 2006 at 7:31 pmHi
I recently purchased eyelashes from a site and they are on a transparency. Is it possible for me to make these transparencies into brushes? If so, how do I do it. I still consider myself a newbie in photoshop SC2 so if you can talk me through it I would be so grateful.
Thank you
KelleyPaul Benson replied 19 years, 10 months ago 3 Members · 5 Replies -
Kelley Neff
October 25, 2006 at 6:09 pmHi. I’m sorry, but I didn’t understand your screen shot. Here’s a photo of the transparency with eyelashes. Here is a link where you can see the transparency with the eyelashes.
https://www.kelsphotocreations.com/misc.htm
Thank you -
Kelley Neff
October 26, 2006 at 7:54 pmI’m sorry. I don’t think I explained myself right. What I need is for the transparency that I received that has the lashes on it, its black background and white lashes. I need to be able to take these lashes and make them into brushes in photoshop, but I cannot select anything because the transparency is all merged together. I tried to invert so the background was white and the lashes were black, but I still couldn’t select any lashes to make a brush with. Does that make sense?
Doug Graham
October 31, 2006 at 5:23 pmChange the lash color to black, or whatever it is you want to use. Use the magic wand selection tool to select the background by clicking anywhere in it.
Invert Selection.
Copy (CTRL+C).
Open the image you want to paste the lashes into and Paste (CTRL+V)
Regards,
Doug Graham -
Kelley Neff
October 31, 2006 at 7:33 pmHi
I thought this was really going to work and I did everything you said. I just painted over the eyelashes black. The I used the wand and clicked and this turned the background white. I then copied this background and tried to paste it into a transparent background, but it only pasted the white. Did I do something wrong? -
Paul Benson
November 20, 2006 at 8:49 pmTo me, the whole pic looks inverted, so you may want to invert the picture first. Select one of the eyelashes with whatever method you prefer. In the Edit bar choose Define Brush Preset. It should now show up in your brush list (make sure you switch to paintbrush) and is most likely on the bottom of the list. If you have a tablet, you may want to have it orient according to the tilt of your pen. Note: I have CS1, but I doubt much has changed in this area – if so, this may give you the proper pointers.
Pauley
