Activity › Forums › Apple Final Cut Pro Legacy › Changing a sequence from anamophic to not….
  • Changing a sequence from anamophic to not….
    Posted by Kevin on August 10, 2007 at 1:27 am
    Hi list,
    I hope someone can help me with a question. I edited JVC HD media in an NTSC sequence with the anamorhic option checked, so I have letterbox which I don’t want.
    Is there anyway I can create a new sequence without anamophic checked and still use my edit.
    Right now when I copy and paste the existing sequence, it becomes stretched.
    Is there a way I can use xml or any other too to recreate the edit in a the new unamorphic sequence and eliminate the letterbox?
    Any insight would be greatly appreciated.
    Warmest,
    Kevin
    Sean Oneil replied 19 years, 1 month ago 3 Members · 3 Replies
  • Kevin
    August 10, 2007 at 1:28 am
    Just sending a followup so I can get e-mail nofifications!
  • Rafael Amador
    August 10, 2007 at 2:44 am
    So what you want is Letter-boxed (16×9 on top of a 4×3 screen) isn’t it?
    Duplicate your sequence and un-check the Annamorphic.
    Double click one of the clips in the time-line to open it in the viewer window.
    In the Motion tab go to Distort. Change the Aspect ratio from 0 to 33. Now the clip look alright, no?
    Now copy (Com-c) the clip in the time-line. Select all the clips and Option-V (Paste attributes) when the window open check “Distort”. All the clips should change to the new Aspect ratio. Thats all.
    rafael
  • Sean Oneil
    August 10, 2007 at 3:29 am
    Remove attributes.
    Sean
