Activity Forums DaVinci Resolve Changing a power window shape using keyframes.
  • Changing a power window shape using keyframes.
    Posted by Steve Davies on August 24, 2012 at 4:16 pm
    I’ve been using the tracker in both auto and manual mode with a rigid shape but is there any way to animate a polygon so that it changes shape under keyframe control. The tracker is great for following someone’s head until they turn a bit and then a gap appears which I can’t fix without permanently changing the window shape, even in Frame mode. After Effects masks will do it, so surely Resolve can as well.
    Thanks.
    Steve Davies replied 14 years ago 2 Members · 2 Replies
  • Dmitry Kitsov
    August 24, 2012 at 4:33 pm
    Tracker is independent of the key frames so you can use both of them at the same time. A general strategy is to track first and then use key frames to animate the window shape that tracker gave you. For certain cases you might want to use track interpolation in the tracker interface itself when you need to only tweak the motion and not the shape (p415 of manual)
  • Steve Davies
    August 24, 2012 at 5:40 pm
    Great, thanks Dmitry.
