Activity Forums Apple Final Cut Pro Legacy Changing a Positve Clip into a Negative
  • Changing a Positve Clip into a Negative
    Posted by Joe Taylor on May 17, 2006 at 5:45 am
    I realize this is probably very simple but I can’t find anything about how to do it.
    But here it goes. Is there a way (filter) that will alow me to change a Positve Clip (image) into a Neagive Clip (image)?
    thank You
    Watch for “Dead Lonesome” coming to you in Glorious 35mm
    Joe Taylor replied 20 years, 3 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    May 17, 2006 at 5:50 am
    Put on a 3 way color corrector and turn the saturation all the way down to make it black and white, then put on the invert filter from the channel menu.
    Is this what you are talking about? If not, in order to get a positive from a negative, you must multiply by another negative 😉
    Jeremy
  • Joe Taylor
    May 17, 2006 at 6:20 am
    That’s exactly what I was looking for.
    Thanks, Jeremy.
