Activity Forums Maxon Cinema 4D Changing a Polygon’s coordinate
  • Changing a Polygon’s coordinate
    Posted by Frank Ruggiero on January 31, 2013 at 9:25 pm
    Hi Cinema Experts,
    I created an abstract object. I placed it inside a Mograph cloner object so that I can apply MoGraph effectors to the object. (In the Mograph cloner, I set the clones to 1, so that it does not duplicate it).
    What I am doing is using a Plain effector and a PolyFX to the object, so that I may scale up each polygon of the abstract object, one polygon at a time.
    My question is this: Each polygon scales up from the center. Is there a way that I can make a change so that each polygon scales up from its edge?
    Thanks for your help.
    Frank
    Frank Ruggiero replied 13 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
