Activity Forums Adobe Premiere Pro Changing a nested multicam sequence from 720p – 1080p without upscaling
  • Changing a nested multicam sequence from 720p – 1080p without upscaling
    Posted by Matthew Jones on January 8, 2014 at 6:28 am
    Hey… so I have a big problem. :S I’ve got about 14 editing projects in 720p (from 1080p footage) that I need to re-render in 1080p. All of them rely heavily on multicamera sequences and I’m wondering if there’s a way to quickly change the scale of my sequences, without having to just upscale the main edited sequence from 720 to 1080 on rendering (which would obviously not make use of the true 1080p resolution in my base clips).
    If it were After Effects I would simply change the compsition size to 1080p, starting with the sequence I’m using as the basis for my mutlicamera edits and working my way outwards, everything would end up in true 1080p no problem, but since you can’t change the frame size of sequences in premiere, I’m unsure how to do it.
    Of course I could re-edit every single cut by hand in brand new 1080p sequences but that would just be impractical. :S
    Does anyone have any ideas? Would really appreciate any suggestions on this one, I swear there has to be a better way of doing this than re-editing by hand.
    Many Thanks!
    Morten replied 12 years, 7 months ago 5 Members · 4 Replies
  • Paddy Uglow
    January 8, 2014 at 11:22 am
    I think you could make a new 1080 sequence and copy the entire contents of the 720 sequence into it. If you’ve applied scaling to all the clips, you could use “paste attributes” to update the scaling on all the clips.
    Does that sound like it’ll work?
    Good luck
    Paddy, CreativeMedia.org.uk
  • Steve Brame
    January 8, 2014 at 12:18 pm
    Load your 720P sequence in the Source Monitor. Drag that sequence from the Source Monitor into a new 1080P sequence, then scale the nested sequence to fit.
    Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia Quadro 4000 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID0 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC
    “98% of all computer issues can be solved by simply pressing ‘F1’.”
    Steve Brame
    creative illusions Productions
  • Paul Neumann
    January 8, 2014 at 4:15 pm
    Right click on the sequence in the Project Panel and change the Editing Mode to the 1080 flavor of your choice.
  • Morten
    January 8, 2014 at 7:42 pm
    Premiere also has a “Scale to fit” command for clips in a sequence…
    – No Parking Production –
    Adobe CC, 3 x MacPro, 3 x MbP, Ethernet File Server w. Areca ThunderRaid 8…. and FCPX on trial
