Activity Forums Adobe Illustrator Changing a bitmap image to vector
  • Changing a bitmap image to vector
    Posted by Robin_xyz_dion on October 23, 2005 at 7:19 am
    Hi
    I have bitmap logo that I’d like to work on it in After Effects (Invigorator).
    I know it has to be vector + illustrator 8.0 and I’m saving it as .ai in illustrator but I’m geting this message all the time by this logo.
    “There were no usabe vector paths in this file.”
    Robin
    Robin_xyz_dion replied 20 years, 11 months ago 3 Members · 3 Replies
  • Richard Harrington
    October 23, 2005 at 11:06 pm
    There is no reliable /easy way to turn a complex raster logo into a vector.
    Go back to client
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
  • Lriv
    October 24, 2005 at 4:55 pm
    saving an image in .ai format doesn’t make it vector. You’re getting that error because there are no paths… it is still just a bitmap image that you opened/saved with AI. Illustrator CS2 can make vector paths from rastor images, but since you’re using an older version, you would have to recreate the bitmap image in illustrator to get vector paths.
  • Robin_xyz_dion
    October 25, 2005 at 5:37 am
    Thanks lriv I’m gonaa Try That when I get home.
