Activity Forums Adobe After Effects Changine object color in AE 6.5
  • Changine object color in AE 6.5
    Posted by Dennis Leppell on May 13, 2005 at 3:48 pm
    One would think that AE would allow you to instantly change an objects color at certain points on the timeline without creating any additional layers. If it’s possible, I have no idea how to do it. Why are all the simple things so hard? Any help/suggestions would be greatly appreciated.
    Steve Roberts replied 21 years, 4 months ago 4 Members · 4 Replies
  • Barend Onneweer
    May 13, 2005 at 5:27 pm
    If you’re talking about a solid’s colors or text colors, try adding the Hue/Saturation filter and keyframing it’s settings over time. No need to add layers.
    Bar3nd
    Forum COWmunity leader for:
    ADOBE AFTER EFFECTS
    MAGIC BULLET SUITE
    INDIE FILM & DOCUMENTARY
  • Dennis Leppell
    May 13, 2005 at 6:47 pm
    I’m trying to change a solid’s color instantaneously. I’d have to set keyframes 1-2 frames apart to achieve that hue/saturation, causing a ‘flash’ as it tries to go through the color spectrum
  • Scott Spengler
    May 13, 2005 at 10:01 pm
    Dennis,
    Don’t forget about Hold keyframes. Will do exactly what your looking for with just one key per color change.
    Scott
  • Steve Roberts
    May 14, 2005 at 2:18 am
    Render>fill can also be used.
    Steve
