Activity › Forums › Apple Final Cut Pro Legacy › Changin Bit Rate on an Apple Pro Res HQ Export? Possible?
  • Changin Bit Rate on an Apple Pro Res HQ Export? Possible?
    Posted by Ryan Foregger on December 7, 2010 at 5:48 pm
    Hi all,
    I got a deliverable request from a client in Argentina that has me scratching my head. They want Quicktime with the following specs.
    Container: .mov
    Codec: Apple ProRes 422 (HQ)
    Raster: 1920x1080px
    Pixel Aspect : Square
    Colors: Millions
    FPS: Source
    Field Order: Lower
    Data Rate: 60Mbps
    Using Quicktime Conversion out of FCP7 or Compressor, I don’t see an option to change the bit rate. It’s grayed out. I assume because ProRes HQ codec requires a certain automatic bit rate.
    Is it possible for me to make a file to their specs?
    If so, how?
    Thanks in advance
    Ryan Foregger replied 15 years, 9 months ago 2 Members · 2 Replies
  • John Pale
    December 7, 2010 at 6:21 pm
    Nope.
    The bit rate is hard wired into the codec.
    Also 1080i HD is UPPER Field first.
  • Ryan Foregger
    December 7, 2010 at 6:51 pm
    I noticed that about the lower field request. Interesting thing about that, my source file has field dominance at none, and I was able to change it to lower in the sequence without “seeing” any change. But the whole thing seems screwy nonetheless.
    So, 1 vote for not possible…
