Activity Forums Adobe Premiere Pro Changes in Sequences not reflected in PP CS6
  • Changes in Sequences not reflected in PP CS6
    Posted by Kevin Obrien on March 22, 2014 at 4:06 pm
    I’ve got a number of sequences that I brought into a new project in Premiere CS6. I created a “Master” sequences that has all the individual sequences in one timeline (So I could color correct the clips to match each other etc) But if I created a “new sequence” from a sequence in the bin the new sequence doesn’t show the color correction etc that I did in the ‘Master” timeline. Where am I going wrong? ie: how can I have the individual sequences refelct the color correction I did in the Master Timeline?
    Tim Kolb replied 12 years, 6 months ago 2 Members · 1 Reply
  • Tim Kolb
    March 22, 2014 at 4:33 pm
    The way you’re approaching this won’t accomplish what you want.
    In the same way a clip in the bin can’t show you the scaling you applied to the clip in a specific sequence, a sequence used as a source clip does not carry effects applied to it in another sequence.
    To get what you want, you’d need to apply the color correction to the source sequence (or just put the clips on the sequence and skip the extra steps…)
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
