Activity › Forums › Web Design (WordPress, Joomla, etc.) › Changes Images
Changes Images
Posted by Jeff Kelley on May 19, 2008 at 4:30 pmDoes anyone know of a java script that would periodically change an image on the screen? I would like about 25 to 30 images to cycle through on the screen, each one staying on for about 10 seconds.
Right now I’ve just been making a large animated gif, but that not a good way to go about it.
JeffJeff Kelley replied 18 years, 4 months ago 3 Members · 3 Replies -
Curtis Thompson
May 19, 2008 at 4:39 pmhello…
ya – it’s fairly straightforward javascript – you can change an image by altering it’s src property to any url, and then it’s just a case of doing a timeout in between…
i’d start here:
https://www.google.com/search?q=javascript+slideshow
you can find a ton of free ones and examples out there…
sitruc
Abraham Chaffin
May 19, 2008 at 5:00 pmI like to use Dreamweaver’s swap image function executed with the javascript timeout function and an array of images. Here’s an example of that idea in a tutorial:
https://www.communitymx.com/content/article.cfm?cid=651FF
I’ve hacked up a version of that and placed the code below – should work –
Have fun!
<head> <script type="text/javascript"> <!-- // Comma separated list of images to rotate var imgs = new Array('images/1.jpg','images/2.jpg','images/3.jpg','images/4.jpg','images/5.jpg'); // delay in milliseconds between image swaps 1000 = 1 second var delay = 5000; var counter = 0; function rotateimages(){ if(counter == (imgs.length)){ counter = 0; } MM_swapImage('Image1', '', imgs[counter++]); setTimeout('rotateimages()', delay); } function preloadImgs(){ for(var i=0;i<imgs.length;i++){ MM_preloadImages(imgs[i]); } } function MM_swapImgRestore() { //v3.0 var i,x,a=document.MM_sr; for(i=0;a&&i<a.length&&(x=a[i])&&x.oSrc;i++) x.src=x.oSrc; } function MM_preloadImages() { //v3.0 var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array(); var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++) if (a[i].indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a[i];}} } function MM_findObj(n, d) { //v4.01 var p,i,x; if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) { d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);} if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[i][n]; for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document); if(!x && d.getElementById) x=d.getElementById(n); return x; } function MM_swapImage() { //v3.0 var i,j=0,x,a=MM_swapImage.arguments; document.MM_sr=new Array; for(i=0;i<(a.length-2);i+=3) if ((x=MM_findObj(a[i]))!=null){document.MM_sr[j++]=x; if(!x.oSrc) x.oSrc=x.src; x.src=a[i+2];} } //--> </script> </head> <body onload="preloadImgs();rotateimages();"> <img src="images/initialimage.jpg" name="Image1" width="125" height="125" border="0" id="Image1" /> </body>
