Changes done in Color don’t export to Quicktime
I’m working in Final Cut 6. I’m attempting to make changes in Color, but when I export my completed sequence into Quicktime, my .mov looks as if I have made no color corrections whatsoever.My workflow is:
Select all of the desired sequence in FC
Send to Color
Make appropriate changes
Save in Color
Render
Send to FC (new sequence “from Color” appears in bin and shows changes)
Open and select sequence
Export to QuicktimeLike I said, when I open the file in Quicktime none of my color corrections seems to have exported. (And I do have that “enable FC color” preference checked.)
I also attempted to open the .mov file in VLC to see if the colors showed elsewhere, but I got an error message- “No suitable decoder module- VLC does not support the audio or video format APCH. Unfortunately there is no way for you to fix this.” The audio does play, so I assume its referencing a problem w/ the video.
Help, please?
