Activity Forums Adobe After Effects Changes doesn’t show on preview as I’m changing the value
  • Changes doesn’t show on preview as I’m changing the value
    Posted by Ditha Angraini on September 16, 2013 at 9:49 pm
    Hi, sorry if the subject didn’t say much. I don’t know what to call it (I’ve only just had access to AE and started using it more frequently in the past three months, and I’m doing a lot of tutorials at the moment).
    I came across a tutorial awhile back, one part of the tutorial involved in activating/deactivating something that allows me to drag numbers in the layer’s properties but the changes won’t take place until the number is set. For example, if I’m dragging the scale number on the comp, the object on the preview monitor doesn’t change as I drag this number up/down until the number is set. I think I’ve turned on this feature then, but I didn’t turn it back off (and I can’t remember which tutorial it was). Can someone please let me know how can I get this back so I can drag the numbers and the changes shows on the preview window as I’m doing it?
    I hope this make sense, I’m trying my best to describe the problem I’m having.
    Thank you very much for the help.
    Ditha Angraini replied 13 years ago 2 Members · 3 Replies
  • Todd Kopriva
    September 16, 2013 at 11:37 pm
    Dave is correct.
    See this:
    https://forums.adobe.com/thread/737571
    After Effects team blog
  • Ditha Angraini
    September 17, 2013 at 4:25 am
    Live update! That’s the term I’ve been looking for. Thank you so much 🙂 I’ve found the button and now all working the way I want it. I knew it was something simple but couldn’t remember which one was it and what it’s called.
    Thank you very much for the help 🙂
    Dee
    https://dithascreativejourney.wordpress.com
  • Ditha Angraini
    September 17, 2013 at 4:26 am
    Thank you very much for the help 🙂 Working fine now.
    Dee
