Changed of graphics card on Mac Pro2009 !! now SSD??
Using the information below:-
Is it worth me buying a ssd drive for the mac Pro?
I have just had to buy a new graphics card.
Buying a new Black mac pro is out of the question financially.
So how far do I go in upgrading this?
As I am HD working mostly on FCPX 10.1.1. and after effects.I have a mac pro 2009
2 x 2.66 Quad Core intel Xeon
20 GB 1066 MHz DDR3
Early 2009 Mac PRO
software OS x 10.9.1
Graphics card Radeon HD 7950 sapphire 3 GBModel Name: Mac Pro
Model Identifier: MacPro4,1
Processor Name: Quad-Core Intel Xeon
Processor Speed: 2.66 GHz
Number of Processors: 2
Total Number of Cores: 8
L2 Cache (per Core): 256 KB
L3 Cache (per Processor): 8 MB
Memory: 20 GBI have been and am pretty happy with this…. its just that I don’t understand something”-
how to work out what the difference would be.?I recently had to change the graphic card. I was using nvidia GT 120 and it crashed about 6 times a day (was fine with lion)… looking through the forums it seemed that the card was the problem esp as Mavericks resorted to a macs default generic video driver.
I asked around and there were very very few graphics cards available. Most suppliers have no stock. So I bought this card. graphics card Radeon HD 7950 sapphire 3 GB. rightly or wrongly… If I scrub quickly along the time line FCPX now longer crashes and seems that the card is coping with the display refreshes. But how does the graphics card make a difference with this next question:-What if any does a graphics card have to do with rendering times.?
Having upgraded the card… I started looking at SSD’s but this 2009 is only SATA 300.
So to test benchmark test I did this.I made a 3 min project added transitions, effects etc…..deleted the render files and timed each of the renders on each of my HARD drives. The results puzzled me particularly on the MacBook Pro retina which IS ssd flash. ….everyone tells me sad is MASSIVELY faster. !! but how much?
these are the tests off the Mac PRO, (all drives 50 %or so empty. computer restarted afresh.)
Mac Drive 1.39 mins
Physical Drive: 7200 RPM
Media Name: WDC WD6400AAKS-41H2B0Velociraptor 1.19mins
Physical Drive: 10000 RPM
Media Name: WDC WD3000HLFS-01G6U02nd drive 1.23mins
Physical Drive: 5400 RPM
Media Name: WDC WD20EARS-00MVWB0BUT below are the tests off the Mac PRO RETINA
Latest high spec Macbook pro retina.
these are the tests off the Mac PRO. I know its only 2 core but the result was a staggering render time of …………………. 5 mins !!! this does not tell me anything about how a ssd compares. but it is a good portable machine. 16 gb ram.Model Name: MacBook Pro
Model Identifier: MacBookPro11,1
Processor Name:
Processor Speed: 2.8 GHz
Number of Processors: 1
Total Number of Cores: 2
L3 Cache: 4 MB
Memory: 16 GBSo how can I tell if its worth buying a ssd for this 2009? how much difference will it make?
should I put in a SATA 600 pcIE card too? what can I do to the existing machine to improve things. if any?I bet you all tell me to start saving !!!
Cheers. AnitaThanks for all your help
Anita Sancha.
