Activity › Forums › Apple Motion › Changeable objects
  • Changeable objects
    Posted by Schlanger Tamás on September 21, 2012 at 10:34 am
    I was planning to change the shape of a rectangle (3d, using replication) to an other with a kind of leaking effect, but the possibilities to change the control points of a rectangle are quiet poor in keyframe editor.
    Now I am looking for a possibility to “fill” the rectangle to inside an other using “preserve opacity”, but I would need the second rectangle to be invisible but showing only the first rectangle inside.
    Is it understandable?!
    Thank You
    Schlanger Tamás replied 14 years ago 3 Members · 4 Replies
  • Simon Ubsdell
    September 21, 2012 at 11:31 am
    [Schlanger Tamás] “the possibilities to change the control points of a rectangle are quiet poor in keyframe editor”
    Is your specific problem that you can’t alter the keyframe interpolation?
    Simon Ubsdell
    http://www.tokyo-uk.com
  • Schlanger Tamás
    September 22, 2012 at 10:51 pm
    Yes, I can not edit every single points of a rectangle.
    And this is aggravated with a bug in Motion 5.0.3: when I change one or more points I get one single keyframe in keyframe editor (without value, determined only in time) but if I move (right-left) this keyframes it donesn’t take effect at all, only if I delete all of them..
    The described method what for I am waiting some help is just a secondary way.
    I am stuck a bit..
  • Mark Spencer
    September 22, 2012 at 10:55 pm
    That’s not a bug, that’s how keyframing control points works. It’s an aggregate keyframe in that channel.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Schlanger Tamás
    September 23, 2012 at 9:43 am
    I understand this aggregate keyframe concept.
    The bug is I think that after taking some aggregate keyframes I can not change the result with moving this keyframes in time. So it seems the rectangle is not in connection with this aggregate keyframes.
    Don’t you have this experience?
