Activity › Forums › Apple Final Cut Pro Legacy › Change video to fit a specific size
  • Change video to fit a specific size
    Posted by Brian Frank on November 24, 2010 at 5:17 pm
    I’m moderately new to the FCP/Compressor workflow, so I apologize in advance if this is a simple, silly question.
    I am being asked to take a video that is currently a 1280×720 and do two things:
    1) Scale it down to size with 408px on the vertical axis
    2) Then crop the left/right sides of the video so it is 337px on the horizontal axis.
    I know that this seems odd to trim the video, it certainly seems that way to me. But I am tasked to do it nonetheless. It is placing in an InDesign document for an iPad app. No matter how I enter the info into Compressors Geometry tab, it does not seem to work. Any help would be appreciated.
    Rafael Amador replied 15 years, 10 months ago 3 Members · 5 Replies
  • Brian Frank
    November 24, 2010 at 5:32 pm
    Unfortunately, we don’t have that in the office as of right now. I can probably get it, but not before the deadline has come and gone for this project. Sorenson Squeeze is also something that is supposedly coming, but again, not before deadlines.
  • James Disch
    November 24, 2010 at 6:53 pm
    Hi Brian,
    I would export your video with it’s native dimension,(1280×720) and then import that .mov into your FCP project. Then make a new sequence with the custom dimensions you need. Drag that .mov into the custom sequence, render it out and you should be good to go.
    James Disch
    https://www.rapidlightproductions.com
    http://www.rapidlightproductions.com
  • Brian Frank
    November 24, 2010 at 7:58 pm
    That’s not a bad idea, but that crops the vertical as well. I need ti have the video scale down to match what is needed on the vertical axis, then crop in to match what is needed on the horizontal axis.
  • Brian Frank
    November 24, 2010 at 10:13 pm
    Not at all. Might have to see if we have that and can try to dive in
  • Rafael Amador
    November 24, 2010 at 10:34 pm
    [James Disch] “I would export your video with it’s native dimension,(1280×720) and then import that .mov into your FCP project. Then make a new sequence with the custom dimensions you need. Drag that .mov into the custom sequence, render it out and you should be good to go.”
    Using only FC, I would do it right this way.
    I would export the final movie to 8/10b Uncompressed.
    With that weird size some compressed codecs could cause some problems on the edges.
    rafael
    http://www.nagavideo.com
