Activity Forums Adobe After Effects Expressions change value every 5 frames
  • change value every 5 frames
    Posted by Eden Exposito on November 18, 2008 at 1:00 pm
    Hi!
    Im here again jejejeje
    I have a 5 FPS composition and i need change values every 5 frames not every frame. Eg, wiggle change value every frame but i need change one control random every 5 frames.
    thanks!!
    Dan Ebberts replied 17 years, 9 months ago 2 Members · 3 Replies
  • Dan Ebberts
    November 18, 2008 at 3:31 pm
    So you need it to change once per second, is that correct? Just add this as the first line in your expression:
    posterizeTime(1);
    Dan
  • Eden Exposito
    November 18, 2008 at 5:49 pm
    ey Dan!
    thanks for your fast response.
    Well i need change value of the wiggle 1 time every 5 frames.. 5 times for second (25fps Pal).
    Maybe
    PosterizeTime(0.2); ??
  • Dan Ebberts
    November 18, 2008 at 5:59 pm
    Ah, then try this:
    posterizeTime(5);
    Dan
